wouldvalue comments on thisspec office/homeuse
ron2fs
COOLERMASTER ELITE 311 BLUE CASE
Intel® Core™i3 Quad Core Processor i3-8100 (3.60GHz) 6MB Cache
ASUS® ROG MAXIMUS X HERO: ATX, LGA1151, USB 3.0, SATA 6GBs - RGB Ready
8GB Corsair VENGEANCE DDR4 2666MHz (2 x 4GB)
1st Hard Disk
6TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 128MB CACHE
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Genuine Windows 10 Professional 64 Bit - inc DVD & Single Licence
Monitor
Samsung LS22D300HY/XU 22" Monitor
Monitor Cables
1 x 2 METRE DVI-D CABLE
LOGITECH® MK270 WIRELESS KEYBOARD & MOUSE COMBO
PCS EXTRA-CARE DELIVERY TO UK MAINLAND - MON-FRI, PRE-NOON
Price £1,108.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/Z3GnHfzXZb/
It's not a well-balanced build.
The motherboard is insanely expensive and intended for extreme overclocking rather than modest home/office use. On the other hand the CPU is pretty basic, the case is cheap and lacks front-facing USB 3.0, 16gb RAM would be better, the HDD is gigantic and expensive, you're adding a wifi card when the mobo already has it, etc etc..
What's your budget and what exactly will you be using the PC for? Any software in particular?
ron2fs
Oussebon, many thanks for valuable comments i chose the motherbord because the standard board was on long delivery. I will look again the main software will be office365, then coffee cup for webdesign madix for music handling my budget is £1000
ron2fs
I'm have already upped to 16gb and what cpu would you recommend i am using pc for database development using access and excel vba
Rakk
The Awesome
I'm havealready upped to16gb amd whatcpuwould yourecommend iamusingpcfor databasedevelopment using access aneexcelvba
ron2fs it would be really helpful if you could add spaces between words, makes the post a lot more readable cos whilst it is sorta readable people may not always read it right, for instance 'aneexcelvba' I'm assuming is actually meant to be 'and excel vba' but I could be wrong as I was guessing whether the first three letters were a typo or not :)
Tony1044
's why I suggested a new keyboard in my first post ;-)
ron2fs
here latest spec
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
SHARKOON VG4-W GAMING CASE (Green LED)
Intel® Core™i5 Six Core Processor i5-8400 (2.8GHz) 9MB Cache
Gigabyte Z370 HD3: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2133MHz (2 x 8GB)
1st Hard Disk
Monitor
Monitor Cables
Price £975.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/fjgqaA!uD8/
I have left the wireless card in because I assume i would need it for home network laptop, printer, bose 3300 soundbar, and tv
i apologise for my typing. I am recovering from a stroke, so any typing is difficult.
Rakk
The Awesome
iapologiseformytypimg. I am recovering from a stroke, so anytyping isdiffigult.
That's ok, I'll try and add the spaces for you when I can, but sometimes it may be tricky for me to work it out :)
Your spec above in this post: https://www.pcspecialist.co.uk/foru...office-homeuse&p=403595&viewfull=1#post403595
looks good to me.
The Sharkoon case is fine for your purposes, but it's not amazing for cooling. If it were ever your intention to add a graphics card (e.g. for gaming, video editing) or to pass the PC on to someone who might, the Game Max Falcon would be a better choice. Also you can configure the LED fan colours on that, instead of being stuck with green :)
Your original spec was £1100 rather than £1000. If you did have an extra ~£100, you might like to add a PM961 or SM961 SSD from trhe M.2 SSD Drive menu. An SSD can be a huge asset for productivity and speed up using the PC, including making Windows load faster.
