Would you change anything ?
Numpty
Just ordered a bit of a beast but after much looking and checking best I could I wondered if anyone had some thoughts on what they might have done differently...
Just ordered so if there's somewhere I can improve on this I'd love to hear about it..
Case CORSAIR GRAPHITE SERIES™ 600T WHITE MID-TOWER CASE
Overclocked CPU Intel® Core™i7-4770k Quad Core (3.50GHz @ max 4.40GHz)
Motherboard ASUS® MAXIMUS VI HERO: PCI-e 3.0, SATA 3.0, USB3.0
Memory (RAM) 32GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (4 x 8GB KIT)
Graphics Card 3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card 3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
1st Hard Disk 240GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
2nd Hard Disk 2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® GOLD MODULAR
Processor Cooling Corsair H100i Hydro Series High Performance CPU Cooler
Network DUAL-BAND WIRELESS 802.11N 450Mbps PCI-E CARD
Operating System Genuine Windows 8 Professional 64 Bit - inc DVD & Licence
DVD Recovery Media Windows 8 (64-bit) Professional DVD with paper sleeve
Keyboard ROCCAT™ Isku FX – Illuminated Gaming Keyboard
Mouse ROCCAT™ Kone XTD – Max Customization Gaming Mouse
Webcam Logitech® HD Webcam C920 - 1080p recording & 720p video calling
This will be hooked up to 3x Dell U2412M monitors and used for video editing, after Effects, 3DS MAx and of course some serious gaming....
Looking forward to a few opinions on where this could be improved.
YAMAHA
You could improve it by going with Win 7 64x :yes: Have you used Win 8?
Numpty
@YAMAHA
After some poking around it seems you made a great point, 8.1 update seems to only offer a partial solution to the hideous metro interface and attempt at returning the start menu and there are a few compatibility issues with 8 and some software and game a couple of years old....
Win 7 it is, order changed, thanks.
There are probably better places to say it, and I'll find them, but PCSpecialist have a great system for ordering, keeps you well informed of the progress and changes like this are so easy and show in the system straight away..
I have in the past used a 'similar' company for a custom build and was quite happy with them but these guys are showing how it should be done...
If the system arrives with the build quality the reviews out there suggest then I'll be shouting their name from the roof tops... Well almost, I run a few sites that will definitely feature a glowing report of my experiences.
