Would like some info (noob stuff)
As I said in the title I am a complete noob to computer building, I know some of the basics but would be interested on hearing what some of you more experienced guys have to say.
Currently I am contemplating buying a PC to finally switch to PC gaming, I have a budget of around £1200 - £1300. I would like to play the current games at highish settings and even some in the future (at highish settings as well) if that's possible.
The main questions:
- Do I need an overclocked CPU?
- Should I run crossfire/sli or have a single but better graphics card? (And witch graphics cards would you suggest?)
- Would a Cool Master CM Storm Trooper suffice for a case?
- And finally what cooling units would you suggest for the CPU and how many fans in general?
Sorry for the amount of dense questions but it would help a great deal if I could get some feedback :yes:
Maybe you could even suggest a build?
Andreas
tom_gr7
Life Serving
1 - gaming no OC is required.
2 - Single screen on a 60hz/60 frames monitor, only one gpu is required.
3 - hell yea, sick case :)
4 - standard case fans will be fine with most "gaming cases" and the triple copper cooler is the cooler to choose for non OC's.
tom_gr7
Life Serving
here's a spec.
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Intel® Core™i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
ASUS® Z87-K: ATX, USB2.0, USB3.0, SATA6GB/S, XFIRE - cant sli with this board though, if you wanted to do that then up this one notch.
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready Great card, only two cards stronger cards at the moment are the 780 and the GTX titan
120GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW) For you OS and main programs
1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) games/steam/origin and other stuff here.
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£79) FYI two 770's would need a 750w psu... But i'd go for an 850W if you want two cards.
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler (£19) More than good enough for Non OC's
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence (£79) Make sure you get 64bit
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5) Dont forget this :)
Price: £1,191.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-pc/Xwax2SwBII/
I'd suggest going with the Vanquish 912 from the review section:
http://www.pcspecialist.co.uk/reviews/
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i5-4670k Quad Core (3.40GHz @ max 4.20GHz)
ASUS® Z87-A: ATX, USB2.0, USB3.0, SATA6GB/S, SLi, XFIRE
16GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 8GB KIT)
4x BLU-RAY ROM DRIVE, 16x DVD ROM
Corsair H60 Hydro Series High Performance CPU Cooler (£59)
Creative Sound Blaster Z 5.1 PCI-E Soundcard - OEM (£55)
Price: £1,199.00 including VAT and delivery.
Hi, thanks for all your feedback. I am now thinking of going for this:
Intel® Core™i5 Quad Core Processor i5-4670K (3.4GHz) 6MB Cache
2nd DVD/BLU-RAY Drive
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£89)
Corsair H40 Hydro Series High Performance CPU Cooler (£39)
WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
This all comes in at £1,254.00
Incase you were wondering I have specced:
- 750w power supply for more expandability in the future.
- Corsair H40 CPU Cooler for a possible overclock in the future (if I'm feeling brave)
- Wireless 802.11N PCI-E CARD for wi-fi - However I don't know if the motherboard with wi-fi needs a network card so that would be something I would like to now :)
I would really like to know any more suggestions/improvements - if I have been stupid anywhere please tell me, not got much experience in this :/
Andreas
P.S wondering about the network card - do I need it or should I spec it on the motherboard?
Hi thanks again for all the help, one last question:
- Would this case be able to fit two of the longest graphics cards? (I don't any examples or measurements I'm afraid :/ )
Thanks again,
Andreas
tom_gr7
Life Serving
Personally, I wouldn't want to put two top of the range gpus inside the storm enforcer. it only has one intake fan which needs to feed two gpu's and a cpu cooler. It would be fine for single gpu setups but i dont think it will be good enough for dual cards.
also get the h60 over the h40 - in short the h40 is very loud due to a low quality fan thanks to corsair.
tom_gr7
Life Serving
Okay I will definitely do that, for any dual - GPU setups what case would you suggest?
Andreas
well, it what cases do you like? lol we may have different tastes haha. The Enforcer is a good case, but as I said it only has the one intake fan, therefore could cause problems later on down the line when you had that extra 770.
Any case that has a couple of intake fans (or options for intake fans) would be my suggestion.
Sounds reasonable, not got plans for any Dual - GPU setups for a while :D
I know I said that was my final question 2 questions ago but I have another one:
- is a SSD worth it for gaming? (And what would I use it for: caching etc.)
Thanks Andreas
It is not essential, if your budget allows it without compromising other components go for it as the primary drive to speed up windows.
