thatsomeguy
Hi all. It's my first time putting together a tower PC (always used workstation laptops) so wanted to make sure I wasn't missing anything and that I was picking sensible parts. Some notes on how I intend to use the computer:
FRACTAL DEFINE 7 XL BLACK QUIET TOWER CASE - Window
Intel® Core™ i9 16-Core Processor i9-12900K (3.2GHz) 30MB Cache
ASUS® ROG MAXIMUS Z690 HERO WIFI (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
64GB Corsair VENGEANCE DDR5 5200MHz (2 x 32GB)
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR
1TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6000MB/W)
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
Corsair iCUE H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Windows 11 Professional
Some additional questions I had:
- Video Editing (working with raw and 4K footage frequently, Adobe Premiere)
- Motion Graphics (Adobe After Effects, nothing too crazy, mostly 2D)
- Colour Grading (Davinci Resolve, not my main focus)
- Gaming (all sorts of games, new and old, using a 3440x1440 monitor as my main, and occasionally a 4K TV)
- Networking-wise, I have a WiFi 6 router with a 2.5GbE port (will mostly be using WiFi) and 500mb Full Fibre so want to be able to take full advantage of these. I also have a NAS I use for synced backups of my working drives.
- I'll be using Thunderbolt 4 peripherals (dock, drives, etc.)
- I'd like for the computer to be as quiet as possible when under sustained loads, but understand the limits of this
- Not interested in using any RGB lighting and not interested in aesthetics as I won't see the computer where I intend to place it.
- Is adding a graphics card support bracket worth doing?
- On the PCS build page, there is an "Extra Case Fans" section. Are these just fans I can buy to swap out or would these be added to the system on top of the fans that are already there? The options go up to 5 extra case fans. If these are additional fans, should I consider adding any?
