Hi!
I need a little help with a custom PC.
I would like to use it for graphic designing, video editting and for gaming.
I made two setups, the first is cheaper, the secound is a bit more expensive.
The main difference is the mother board and the processor, and unfortunately i can't use intel optane memory in the second setup because of a compatibility issue.
(I would appreciate if somebody could explaint to me the possibble reasons why i can't use the optane memory to the HDD because of an SSD.. )
One monitor, later maximum two monitor will be used.
Adobe programs for work, and not competitive gameing, just casual gameing.
Which is better for work station?
Should i change anything?
First €2,021.00:
CORSAIR CARBIDE SERIES™ 275R TEMPERED GLASS GAMING CASE
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
Get Call of Duty: Black Ops 4 & More w/ select Intel CPUs!
Gigabyte Z390 AORUS PRO: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2666MHz (4 x 4GB)
8GB NVIDIA GEFORCE GTX 1070 Ti - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
2TB SEAGATE BARRACUDA PRO 3.5", 7200 RPM 128MB CACHE
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
Intel Optane Memory
16GB INTEL® OPTANE MEMORY - USE WITH MECHANICAL HDD
NOT REQUIRED
1 x 1 Metre European Power Cable (Kettle Lead)
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
Second €2,268.00 :
Intel® Core™ i7 Eight Core Processor i7-9800X (3.8GHz) 16.5MB Cache
Gigabyte X299 UD4 PRO: ATX, USB 3.1, SATA 6 GB/s - RGB Ready
16GB Corsair VENGEANCE DDR4 2400MHz (4 x 4GB)
NOT REQUIRED
I would prefer more the secound setup, but as i heard the optane memory would be handy..
Thank you in advance!:helpsmilie:
First €2,021.00:
Intel Optane Memory
NOT REQUIRED
Second €2,268.00 :
NOT REQUIRED
