Just looking for some help...
Built a laptop from PS in May last year...
it holds 2 HD's so installed my Agility 3 SSD as main drive. I have my own windows 8 op so installed it and so far everything has been running spot on until today.
I was running the laptop for 30mins walked away and came back to a black screen saying this....
Windows failed to start. A recent hardware or software change might be the cause.
options
1. insert windows disk and reboot
2. choose language setting then click next
3. Click repair computer
File: \Windows\system32\winload.exe
Status: 0xc000000f
Info: the selected entry could not be loaded because the application is missing or corrupt.
I have tried a repair and it doesn't work. but if I push F7 on boot up and select my SSD from the boot options it boots right into windows 8. I have even tried to restore to an older date no luck. done a disk check and the drive is showing fine.
My alternative is a windows format and trying again.
I posted this info on another forum and they have suggested it could be down to a bad CPU or mainboard (setting aside an unfixable windows driver) or a dodgy hard drive or controller.
Looking for some other solutions really...I've seen 2 posts so far on here relating to this and PCS advise is to send the product back for testing which I don't mind doing...figured perhaps I should try a new windows install first to see if the problem ongoing or not?
It's still under warranty.
thanks
options
Status: 0xc000000f
thanks
