Hi all. The IR remote doesn't work after reboot so I have to uninstall and reinstall it (using 2.8a driver link from Hauppauge site then it works fine again). Anyone else have this problem please?
It's a nuisance as it takes about 20 mins to do that. There is an IR Restart exe but although that worked on Windows 7, it doesn't on 10, for me at least. Any ideas? Thank you.
Another issue with WinTV V7 I experience is an error which is fine if just quit and open again, but it somehow causes all my recordings list to be shown in triplicate, or if error arrives again in sixtuplicate or nine-tuplicate. TBH I don't think this has happened since on Windows 10 so maybe that was a W.7 issue?
My computer has been fine since I bought it here - it'll be 2 years old in a couple of months - and thanks again for extensive help on the initial spec I received.
Regards and Happy New Year
mautal
mautal
