Windows 10 Numlock fix
films&games
I have looked at the "Downloads" section of my PCS account and there is a Windows 10 Numlock Fix zip file along with the Windows 10 Recovery Image.
Is the Windows 10 Numlock Fix needed?
Any advice or suggestions would be appreciated, please.
Thank you.
Linda
I would also be interested in knowing this as both are also showing in my downloads even though I have not yet received my build yet it has been in pre production 9 days now and told it is not going into build until the 10th Feb.
films&games
What is the full spec?
The full spec:
CORSAIR OBSIDIAN SERIES™ 750D FULL TOWER CASE
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
Get 3 Months of XBOX Game Pass for PC w/ select AMD Ryzen CPUs
The Outer Worlds -OR- Borderlands 3 w/ select AMD Ryzen CPUs
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1TB CORSAIR MP600 GEN 4 PCIe NVMe (up to 4950MB/R, 4250MB/W)
16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & SOFTWARE
LED Lighting
50cm RGB LED Strip
Windows 10 Professional 64 Bit - inc. Single Licence
Monitor
IIYAMA G-MASTER GB2760QSU-B1 27"
This might be related to a problem on some machines whereby the NumLock key is turned off on reboot despite the BIOS setting turning it on.
I would suggest you download the file and extract it. You should find some sort of readme file in there that explains exactly what it's for and how to use it. [emoji3]
