kruppsy
Master
This is a bit complicated so i'll try to explain as best I can.
I have a partitioned Hitatchi HDD. One partition has XP one has Vista. I recently bought A WD Caviar Black HDD and cloned the Hitatchi straight over deleting the XP partition. Now my PC boots from the WD into Vista and the Hitatchi is my second HDD but remains intact as it was.
Ok. I had Battlefield Bad Company 2, installed on my XP partition of the Hitatchi, which i registered for online play (in other words the serial is used), but i now want it on my WD HDD. If I do a re-install I assume when I put the serial number in, i'll be blocked from online play? However, if I just copied all the data from the Hitatchi over to my WD will it work? Bearing in mind its being copied from an XP partition to Vista and I have no idea if regsitry files are also needed as part of DRM?
Im just trying to get round buying another copy when I have it on one of my HDDs already.
Sorry if thats all illegible
