Will This Work/Is This Good?
LexiLndn
Hello,
built a spec for my younger brother.
Just wondering if all parts are combatible and if they will work?
If there are better options please let me know!
Budget: £630
UltraNote Series: 15.6" Matte Full HD 60Hz 45% NTSC LED Widescreen (1920x1080)
AMD Ryzen™ 5 6-Core Processor 4500U (2.3GHz, 4.0GHz Turbo)
8GB Corsair 2133MHz SODIMM DDR4 (1 x 8GB)
AMD Radeon™ Graphics (CPU Dependant)
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
AC Adaptor
1 x 65W AC Adaptor
UltraNote Series Integrated 36WH Lithium Ion Battery
WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
1 x USB 3.2 GEN 2 PORT (Type C) + 1 x USB 3.2 GEN 1 PORT + 2 x USB 2.0 PORTS
MULTI COLOUR BACKLIT UK KEYBOARD
Carry Case
Tech Air 15.6 Classic Toploading Case
Mouse Pad
PCS Mouse Mat
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NL51RU FHD (R5-4500U, FHD, 60Hz N4, Blank KB)
Standard Build - Approximately 14 to 16 working days
Price: £614.00 including VAT and Delivery
Hi there,
If you can post the link to the build this will allow us to easily go in and make changes. If you click "Proceed" and then "Post to forum", you will be able to copy and paste the entire configuration along with the easily accessible link from the bottom.
Is it a laptop for school use etc? It won't be any good for gaming but it should do very well for school work and the like. I would attempt to increase the RAM speed if you can and I would select an M2 drive over the SSD, otherwise all good.
LexiLndn
Hi there,
yeah he's quite adament that he won't use it for gaming but i know he will, probably only really minecraft.
Yes, he's using it for school mostly.
Link and config:
AC Adaptor
1 x 65W AC Adaptor
Carry Case
Mouse Pad
PCS Mouse Mat
Chassis
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/initia-amd-15/We7QpPH073/
No worries at all. The configuration should do very well for that use. I've made the changes I would suggest below...
8GB Corsair 2666MHz SODIMM DDR4 (1 x 8GB)
AC Adaptor
1 x 65W AC Adaptor
Carry Case
Mouse Pad
PCS Mouse Mat
Chassis
Price: £630.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/initia-amd-15/hzpzXWVKea/
