Will this be a good all rounder?
CybrHwk
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache
ASUS® SABERTOOTH X79: SOCKET 2011, R.O.G
16GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P(4 x 4GB KIT)
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd DVD/BLU-RAY Drive
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
CORSAIR 1200W PRO SERIES™ GOLD AX1200-80 PLUS® GOLD MODULAR(£208)
INTEL SOCKET LGA2011 STANDARD CPU COOLER
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£109)
3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour) (£69)
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON) (£19)
Never done overclocking before but would I be better off with the Rampage Extreme IV? I do a lot of programming and photo editing, is 16GIG going to be enough?
Any other comments/suggestions welcome :)
tom_gr7
Life Serving
I'd suggesting getting pcs to overclock your pc for you, then you are covered with warranty dude.
bg92
Expert
Rampage Extreme IV shoulb provide better overclocking results. Btw why did you choose a 1200w psu? For a single gtx580 its overkill. A 650w-750w power supply would be enough.
16gb of ram should be enough.
I also think that buying an already overclocked pc from pcspecialist would be a better idea. Especially since you would be covered by warranty.
CybrHwk
Thanks guys for the replies. Reason for the 1200W PSU is that I plan on putting in a second 3GB 580 at a later date (if I want to upgrade later, chances are the nvidia card will need yet more power!), along with another hard disk and memory. I just want to spread the cost a bit
I phoned yesterday to ask about CPU Coolers as I can't chose one as its the new Socket 2011, they said it would be Akasa, does that mean I might get a Akasa Venom? Or should I consider Liquid Cooling?
CybrHwk
£2400 ish. Haven't bought a new PC in about 8yrs, so thought I spend a bit more. Currently using an AMD 64 3200+ with 2gig of RAM
tom_gr7
Life Serving
HAve a look into the sandbridge processors and z68 motherboards? I will post a spec up see what ya think.
tom_gr7
Life Serving
\What about this. overclocked by pcs, costs 2012.
Overclocked CPU
Overclocked Intel® Core™i7-2700k Quad Core(3.50GHz @ max 5.00GHz)
ASUS® P8Z68-V PRO/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£159)
ASUS XONAR DG 5.1 SURROUND SOUND PCI CARD (£20 SPECIAL)
Quantity 1
dangro474
Very nice system spec.
A single 580 GTX is enought o run almost all of the most recent title releases maxed out in 1080p (being generous with AA/AF).
Regarding the RAM volume; if this concerns you, you could always opt for 2x 8GB rather than 4x 4GB, allowing you to upgrade to the full 64GB limit without having to replace DIMMs in the future.
