Will PCS install a sound card of my choice if I send it them?
Rakk
The Awesome
Presuming you are ordering a PC from them and you arrange it with them when you order I believe they will do (though I'd give them a call to double-check first)
mantadog
Superhero Level Poster
They will but you will need to order over the phone i think, also make sure it is sent via an insured delivery just to be safe.
sampat
heard it is not hard to so will do it myself
I added the one i have now and its so easy, i followed a video on youtube and it was done in five minutes, just slips in and you hear the click, install drivers, i would check the cards site and not use the disc, be out of date, done , jobs a good un, if i can do it so could Stevie Wonder
todd89
thanks, i have to disable the onboard audio in the bios correct?
