Will my laptop be able to run a 2k moniter?
Segwayrider
Hey.
I Was just wondering if it is possible for my laptop to run a 2k moniter (31.5 qhd (2560x1440), curved 144 hz 4ms response time) and if it would make sence to do so? Like could it run it but the fps would be so low that there wouldnt be a reason to it? And if so can you run a 2k moniter in 1080p?
I´m looking at a screen in the secondary market and assuming I can push down the price a little i might be buy it. Unless it dosnt make sence of course.
my laptop specs:
Stel & DisplayNova Serien: 15.6" Mat Fuld HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)AMD Ryzen 9 3900 12 Core CPU (3.1GHz-4.3GHz/70MB CACHE/AM4)
Hukommelse (RAM)32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
GrafikkortNVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1. M.2 SSD-drev1TB PCS PCIe M.2 SSD(2000 MB/R, 1100 MB/W)
1. lagringsdrev2TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
HukommelseskortlæserIntegreret Micro-SD Hukommelseskortlæser
AC-adapter2 x 230W AC Adaptor
Strømkabel2 x 1 Meter Europæisk Strømkabel (Kettle Lead)
Batteri2 x Nova Series 62WH Lithium Ion batteri
Termisk pastaSTANDARD KØLEPASTA TIL TILSTRÆKKELIG KØLING
Lydkort2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & TrådløsGIGABIT LAN & KILLER™ TRÅDLØS-AX 1650 M.2 GAMING + BLUETOOTH 5.0
Muligheder for USB/Thunderbolt1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTE + 1 x USB 2.0 PORT
TastatursprogNOVA SERIES DANSK TASTATUR
OperativsystemWindows 10 Home 64 Bit - inc. Enkeltlicens [KUK-00001]
Operativsystemets sprogDanmark - Dansk sprog
Windows gendannelsesmedieWindows 10 Gendannelsesfil på flere sprog - Ubegrænset downloads fra online-konto
Office-softwareGRATIS 30-dages prøveperiode af Microsoft® Office® 365 (Operativsystem kræves)
AntivirusBullGuard™ Internet Security - Gratis 90-dages licens inkl. Gamer-tilstand
BrowserMicrosoft® Edge (Kun Windows 10)
Skærmkabler1 x 2 METER DVI-D KABEL
Ændr til INGEN
Notebook-musINTEGRERET 2-KNAPS TOUCHPAD-MUS
WebkameraINTEGRERET 1MP HD WEBCAM
Garanti3 års guldgaranti (2 års afhentning & returnering, 2 års reservedele, 3 års arbejde)
Garanti ifm. døde pixels1 År Garanti ifm. døde pixels Inkl. Arbejde & Befordringsomkostninger
Levering3 DAGSLEVERING TIL DANMARK
ByggetidStandard Konstruktion - Omkring 7 til 9 arbejdsdage
VelkomstbogPCSpecialist Velkomstbog - Danmark
Thank You in advance for your time
I've removed your windows license, be careful what you post online.
It will happily drive 1440p, but laptop GPUs are lower power than desktop equivalents so an RTX2070 laptop GPU is roughly about a RTX 2060 desktop card.
You'd be looking around 60fps on most games at full settings. Just adjust settings to suit.
