Will a 5090 fit my build ?
Over9000!
Hey Guys
So browsing the web it appears a 5090 will fit my case
My cynical self with a tape measure am struggling to see it, can anyone please clarify ?
PS I am aware I need to upgrade the PSU
TIA
CORSAIR iCUE 4000X RGB TEMPERED GLASS MID-TOWER ATX CASE - WHITE
Promotional Item
GIGABYTE B650M AORUS ELITE AX ICE (mATX, AM5, DDR5, PCIe 4.0, Wi-Fi 6E)
32GB Corsair VENGEANCE RGB DDR5 5600MHz CL40 (2 x 16GB) KIT - WHITE
12GB GIGABYTE GEFORCE RTX 4070 SUPER AERO OC - WHITE - HDMI, 3 x DP
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler - WHITE
Microsoft® Edge
Corsair Bundle - K55 RGB PRO Keyboard & M55 PRO Mouse
Miscellaneous
PCSpecialist Game Pass Sheet
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Corsair Carton Upright
Where are your AIO fans/radiator mounted?
If they‘re at the front of the case then you’ll have reduced the available space for a GPU.
If it’s a 360mm limit without the rad/fans at the front, then it may be more like a 310mm limit with the AIO installed at the front (27mm for rad + 25mm for fans).
Over9000!
Yeah PCS installed 3 at the front 2 at the top and 1 at the back, Can the fans go anywhere else to accommodate the card ?
The 3 standard case fans at the front won’t be an issue (as that is the standard config)…it’s only if the Corsair AIO radiator/ fans have been fitted to the front - behind the originals - that it reduces the space.
We can’t tell from the config, so will have to rely on your eyes to tell us.
….and, of course, the GPU length will also vary by model (304-350mm I think).
I have a 4090, and went through all the same worries 2 years ago, but mine has been fine.
I know the 5090 is much effed-up than the 4090 was, but still I wouldn't worry too much, as your warranty will cover a replacement. Just ensure your house insurance is upto date and covers specific expensive items...as I'm not sure if a GPU warranty covers consequential damage.
