Wifi Signal Issues
EdwardH
Just wondering if anyone can help or has any solutions, I received my order yesterday and set it all up but I have been having issues. My internet is connected but the signal is very weak (1/2 bars) all the time I have done the usual reset router etc and it doesn't seem to be my actual wifi that is the problem does anyone have any idea what may be wrong?
Have you attached the antenna?
EdwardH
Can you post your full specs from the order page?
PCS SPECTRUM RGB MID TOWER CASE
Change to: FRACTAL FOCUS G BLACK GAMING CASE (Window)
Processor (CPU)Intel® Core™ i7 Eight Core Processor i7-10700 (2.9GHz) 16MB Cache
Change to: Intel® Core™ i7 Eight Core Processor i7-10700KF (3.8GHz) 16MB Cache
MotherboardASUS® PRIME Z490-P (LGA1200, USB 3.2, CrossFireX) - ARGB Ready
Change to: ASUS® TUF Z490-PLUS GAMING WI-FI (LGA1200, USB 3.2, CrossFireX) - ARGB Ready
Memory (RAM)16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
Change to: 16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 2060 SUPER - HDMI, DP - VR Ready!
Change to: 12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
Processor CoolingCoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
Extra Case Fans3x CoolerMaster SickleFlow 120 ARGB + Controller Kit
Build TimeStandard Build - Approximately 12 to 15 working days
So in the welcome pack should be 2 antenna, they just screw onto the gold screw terminals on the back of the case.
You’ll also need to fully uninstall Bullguard as it’s known to cause issues and windows defender which is part of windows is better anyway.
I suppose all of this could be avoided if PCS only included a note telling new owners where to plug in the monitor and antennae :unsure:
:ROFLMAO:
On that note make sure you attach them to the AX200, as i noticed you have the ASUS® TUF Z490-PLUS GAMING WI-FI (LGA1200, USB 3.2, CrossFireX) - ARGB Ready Motherboard
