Which spec would you go for ???
Brockwinch
PC req mostly for gaming but also want it to run as fast as possible in general use, which spec would you go for ??????
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
AMD FX-4170 Quad Core CPU (4.20GHz/4MB CACHE/AM3+)
ASUS® M5A78L-M/USB3 (M-ATX, DDR3, USB 3.0, 3Gb/s)
8GB SAMSUNG DUAL-DDR3 1600MHz (2 X 4GB)
Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler (£19)
WIRELESS 802.11N 300Mbps PCI CARD (£16)
Total: £ 888
Or......
Case PCS MAELSTROM T900 BLACK GAMING CASE
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
Motherboard ASUS® P8H61-MX USB3/SI: uATX, USB 3.0, SATA 3.0Gb/s
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1600MHz (2 X 4GB)
Graphics Card 2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
2nd DVD/BLU-RAY Drive
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler (£19)
Network Facilities WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
USB Options 4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Operating System Genuine Windows 8 Standard Edition 64 Bit - inc DVD & Licence (£79)
Total: £882
Any input welcomed, thanks.
For gaming only I would consider a different spec from the ones you posted, what type of general use? The FX-4170 is likely to bottleneck the GTX 670, if it is mainly for gaming you wouldn't benefit from an i7.
ASUS® P8H77-M: M-ATX, DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX™
4GB SAMSUNG DUAL-DDR3 1600MHz (1 X 4GB)
Free Item
FREE £100 IN-GAME VOUCHER with GTX 660 & UPWARDS GPUs!
120GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
Price: £844.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/gmM4zGkkrw/
vanthus
Member Resting in Peace
Your first build looks pretty good to me,for gaming you want the best graphics card you can afford,and the 670 is up there with the best,I don't think the AMD FX-4170 will bottleneck the 670 at all unless playing really intensive CPU games,and even then it might not be all that noticeable.
Brockwinch
I've made some changes, it's a little more than I wanted to pay as I've still got to get the monitor, keyboard ect but I'm quite happy with this. I would'nt mind downgrading the motherboard if possible as it may bring the price down a little and am I right in saying the i5 doesn't hyper thread? what do you think ?.?
Case COOLERMASTER CM STORM ENFORCER - GAMING ENTHUSIAST CASE
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3470 (3.2GHz) 6MB Cache
Motherboard ASUS® P8Z77-M: MICRO-ATX, USB 3.0, SATA 6GBs, ATI®CrossFireX
Graphics Card 2GB NVIDIA GEFORCE GTX 670 - 2 DVI, HDMI, DP - 3D Vision Ready
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
Extra Case Fans 2 x 12CM Black Case Fan (configured to extract from rear/roof) (£9)
Operating System Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence (£79)
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
Total: 992
I've made some changes, it's a little more than I wanted to pay as I've still got to get the monitor, keyboard ect but I'm quite happy with this. I would'nt mind downgrading the motherboard if possible as it may bring the price down a little, what do you think ?.?
which spec?
Wow you were a little quick for me there to edit my post after I forgot to add the spec :)
The next motherboard (P8Z77-V LX) on the list is cheaper and it has more expansion slots. I wouldn't worry about cooling with the case you have chosen, I wouldn't add extra case fans. You could consider a caviar black as the main drive.
