Which is your best Full HD screen?
Dommer
Another simple question: which is the best Full HD screen that you do, in terms of accuracy of colour reproduction? I am a bit confused since some of your screens claim 95% gamut which is then reported as 72% when I click on the questionmark by the dropdown selector.
If it turns out that the best screen is a 15.6" model rather than a 17.3", then I could probably go for that instead (and use an external optical drive, since I need an SSD and HDD internally).
If it's a close run thing, then I'd rather get a larger screen. I'd rather get a matte screen, but not if they are much worse than the glossy ones.
Do you know if any "high street" laptops use the same screens as you? If so, I could maybe get a look at them before coming back to you to make my purchase... ;)
EDIT: Is it possible to get a 95% gamut 17.3" screen? Be it glossy or matte...
jubei
As far as i am aware, the best screen is the matte finish screen in the vortex 15.6" chassis. Thats the 95 gamut one at least :)
PCS
Administrator
Staff member
Welcome to our forums :)
The very best screen is the 15.6" AUO B156HW01 V.4 which is available on our configurators. It has a 95% gamut and the reference to 72% has now been corrected.
The highest gamut 17.3" screen is 72% - a 95% model does not exist as far as we are aware.
