Which case for an O.C desktop?
shocksalot
Cant decide which case to get for an O.C build, thermals are the biggest concern here.
heres my build:
Overclocked CPU
Overclocked Intel® Core™i7-2600k Quad Core (3.40GHz @ max 4.80GHz)
ASUS® SABERTOOTH P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, THERMAL ARMOR!
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - DX® 11, 3D Vision Ready
120GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 130MB/sW)
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£49)
STANDARD OVERCLOCK THERMAL PASTE
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
Case budget of £130
Important note: the machine will have to be left running at 100% CPU usage for prolonged periods of time for Rendering out Maya scenes.
Im tempted to go for the Coolmaster sniper.
Let me know any thoughts/advice/experience you have.
Teaz
the sniper, raven and haf x are good for that. you should check your ambient room temps too as if its warm quite tricky or hard to achieve the good low temps you would expect. you should get the artic thermal paste as it will lower some extra temps on the cpu :)
liamnic2
Super Star
The HAF-X. Its massive on the inside with dust filters everywhere and it has big fans. And you can remove the unused hard drive bays which can increase airflow by a good amount. + With the space inside you can put your ALC on the top of the case instead of replacing the back fan or you can replace the back fan and intall an extra 200mm fan.
You can have 4x200mm fans and 1x120mm fan, you cant get anybetter airflow
bg92
Expert
I would go for the Raven 03 or Raven 02
Or maybe go for the Corsair 650D.
Whatever you do don't go for the haf-x, its ugly.
Teaz
lol the raven has really good cooling the way its designed. if not go for the sniper or if you can, grab the corsair 600t. not sure why pcs dont stock them no more as they are real good cases.
bg92
Expert
How dare you.........:p
No offence but it is in the top 10 of ugliest pc cases in history. Its ranked 3rd.
:tt2:
Btw if yuou don't want to go for the Raven go for the corsair 650D, another option is saving a bit of cash and going for haf 912 or 922 or cm 690 II
Fear
:tt2:
Proof where is your proof i demand proof...............unless you can provide me with evidence to use against you i will take no notice of any hurtful remarks to my lady :p
bg92
Expert
I'll show you proof but not now.
***Learning how to use photoshop and making proof***
