Most of the battle against Virus' and malware etc etc is user education on the subject.
No amount of firewalls and anti virus will protect a machine when the user allows themselves to be infected.
As an example, nasty arrives in email, user opens attachment, AV prompts is it safe? user clicks yes.
End result is an infected machine where the AV was not at fault.
So basically (and im not trying to offend anyone in any way here) being careful where you click, what you open and having an air of healthy suspicion when browsing can go a long way to preserving a clean system.
AV + Firewall + Paranoia = Clean system
Microsoft Security Essentials and a firewall set up correctly on your router.
Add in a bit of web smarts and healthy skepticism and you are all set.
I have MSE running.
- What specific/important settings should I be looking at on my router?
- I'll be moving from ZEN to SKY broadband next week or so (a purely financial decision). I believe SKY will be providing a new router. Do I have to use the new router or can I stick with my current Belkin (if so, which would you guys recommend?)
