Which 2060 Super card is used by Pc Specialst
Luis_Shaw
I'm looking to buy the system detailed below, but I would like to know which 2060 super is used here so I can get an Idea of the cooling on the card, I can't find this info anywhere?! Also any suggested changes while i'm here
COOLERMASTER MASTERBOX K500 ARGB GAMING CASE
ASUS® ROG STRIX B450-F GAMING (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
1TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
matman888
I would recommend contacting them. I used the live chat feature on the website to confirm the make/model of the gpu in my build. They were super helpful, came back to me straight away. As long as you do it during the working day, you should have an answer pretty quickly.
Usually Palit or Zotac, although production of the 20xx range of cards is now going to dwindle due to the new models being released soon. I was expecting a Zotac 2070 Super in mine and ended up with a Gainward. Post above is a good call, contact them for advice.
Luis_Shaw
Usually Palit or Zotac, although production of the 20xx range of cards is now going to dwindle due to the new models being released. I was expecting a Zotac 2070 Super in mine and ended up with a Gainward. Post above is a good call, contact them for advice.
Cheers guy's will do
