Where is my MGSV code?
Remersed
I bought a custom PC from PCS and it came with a qualifying graphics card for the MGSV promotion. How and where do I find this code?
Rakk
The Awesome
I will be a code on a colourful piece of paper/card in your welcome pack - note - this is presuming that they hadn't run out (since they are limited stock)
Remersed
Ahh okay. I will go and have a look through the pack again although I already have looked several times - I assume they must've ran out. Thanks for letting me know.
Wikaman1
Nope, I didn't get one either, had to phone up and get them to add it manually to the order, apparently when I ordered there was none in stock (even though people that ordered the same spec soon after me got their code?). Unless it's been emailed to you at time of ordering then phone them up and get them to send you one. Bit annoying having to chase it up several times but I got there in the end.
Warbloke
I can help here:
What you need to do is, use the cover of darkness to sneak into the PCS enemy base and try to mark someone with a high skill ranking in Customer Services.
Approach from behind and press E, then Q to interrogate. (careful here not to press E again to avoid stabbing him in the throat)
Choose the option to 'Spit it Out' and he will give up the MGSV promotional code.
At this point Id recommend FULTONING him
Wikaman1
I can help here:
hahaha, best post I've seen in a while. :D
But yeah it's annoying they literally said nothing, just didn't include it, even an "out of stock" message would have been nice. Another instance of bad communication. :whistling:
moosEh
Administrator
Staff member
I can help here:
Sadly that would not work, first you would have to get past the mine field (PCS Car park). Then when you have navigated rambo style through this you are faced with the warehouse army, armed to the teeth with their lunches.
