Hi all
If you're here, it likely means you're having issues which is not good, so we want to help to make it much better as quickly as possible and get you back into full tilt gaming / rendering / production or whatever is your poison.
It really helps us if we have the full system specifications listed from the order page along with the symptoms you're facing. Reason being is there can be multiple possible influences to one symptom, and seeing the entire specs helps us narrow down where to look.
There's detailed instructions on posting the full specs from the order page here, and please post the lot, don't assume some isn't required, every bit is helpful:
How to Post Your Specification to the Forum - Check this Spec
Just a first note, if you've been provided this link, don't amend your first post as it won't update the queue, please add an additional comment to the thread, that way it will go back to the front of the queue. Otherwise we don't know it's been updated. When creating a forum post looking to...
www.pcspecialist.co.uk
