What would you change?
I ordered this just over a week ago, and was wondering if any tweaks could be made.
Going to take ages to arrive so might as well šŸ™ƒ
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
ASUSĀ® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 850W RM SERIESā„¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
LED Lighting
50cm ARGB LED Strip
ASUS PCE-AX58BT Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
FREE 30 Day Trial of Microsoft 365Ā® (Operating System Required)
BullGuardā„¢ Internet Security - Free 90 Day License inc. Gamer Mode
MicrosoftĀ® Edge (Windows 10 Only)
Welcome Book
Logo Branding
PCSpecialist Logo
Steveyg
Your CPU cooler is woefully underpowered it will not be good enough to keep the 5950X cool, you're going to run into a lot of problems with that
What's this computer for?
Other thing I'd suggest is to remove Bullguard it just causes problems
You also need to add an M2 for your OS it will just make your OS run a lot faster and better
It's not well balanced at all, in fact, it would last about a week before it burnt out.
What's your max budget?
What's it for?
What monitor are you pairing it with, what resolution and refresh rate or make and model if you're unsure?
Going to be used mainly for gaming but also computational chemistry work.
Max budget doesn't really matter too much as student loan is being put to good use.
I've got a dell S2721DGF monitor, 1440p 165hz.
It's a bit all over the place.
So if we aim for £6000 budget? We can do a lot of improvements at around that cost?
That's quite the jump.
If I limit it to about £4000 what could you suggest I do?
Can you provide the configuration link?
Steveyg
I'd be looking at this but I wouldn't buy that processor without the CROSSHAIR HERO VII motherboard, I had to pick the X570-F as an option to post the build but If I was stuck on that motherboard I would go with a 5900X
BE QUIET! BASE 601 TOWER GAMING CASE
2TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
CORSAIR 1000W RMx SERIESā„¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
WIRELESS INTELĀ® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
NO RECOVERY MEDIA REQUIRED
Google Chromeā„¢
Price: £3,384.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/RTpm8Cg4wz/
MrWilson
Looking at your monitor choice, the 3070 might be a better pick here. To make full use of the 3080 you really need a 1440p Superwide or 4k 144hz. I’m assuming that the chemistry stuff is CPU intensive as opposed to GPU intensive, if it does benefit from a higher end GPU that would be an argument to keep the 3080 in.
The 3070 is also in much more plentiful supply so should improve your wait time quite substantially, the 3080 queue is likely to stay long for the foreseeable future.
Bigfoot
Grand Master
Google Chromeā„¢
Given that the OP only had a 2TB SATA drive, does the PC really need 2 off 2TB drives?
Should also make the OP aware that if using the student loan, then bear in mind this may not be ready until this years study is over :D
Is the OP looking for something that will be here quickly or prepared to wait for a while?
I've got a computer that works at the minute so I'm happy to wait
