What should I change?
JayTra
I think its solid though I don't know what I'm doing
PCS PRISM-X ARGB MID TOWER CASE
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
Standard Build - Approximately 14 to 17 working days
Promotional Item
Get Guardians of the Galaxy with select GeForce RTX™ 30 Series GPUs
Welcome Book
Price: €1,562.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/WdqhTBe3uX/
JUNI0R
Promotional Item
Welcome Book
Hi there, few changes we could make. We'll need some info first. What's your budget? What will you be doing with the system and what monitor will it be paired with (either make and model or resolution and refresh rate would be great!) Thanks!
JUNI0R
Nope, was going to get a fresh monitor
I'd highty recommend going for 1080p 144hz then. Only a very small percentage of the population can see above about 120hz so spending the extra for 240hz is throwing money down the drain for most people. Plus, it'll give you more money to spend on improving the build as 144hz is generally quite a bit cheaper than 240hz. What were you planning on spending on this monitor?
JUNI0R
Around 350 euro, I was thinking it would be better than my current monitor, 1440p
I'm a little confused, have you currently got a 1440p monitor? What's the refresh rate on it?
As an aside- going for a 1080p 144hz would cost about 240 euro's giving you another 100 or so euro's to spend on the build which it would really benefit from
JayTra
And if my current monitor is solid as it is I can put the money for the monitor into the pc
JUNI0R
My current is 144 144p monitor tho i thought the downsize might be worth the refresh rate
1440p 144hz is a fantastic sweetspot for gaming right now. I wouldn't personally recommend going from 1440p to 1080p for more frames you're unlikely to see. I'd suggest combining the budgets and getting a better PC.
LIAN LI LANCOOL 215 GAMING CASE Better airflow case
ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! Higher quality motherboard to better handle the 5600X
8GB PALIT GEFORCE RTX 3060 Ti - HDMI, DP, LHR Better GPU that's more aimed at 1440p gaming
1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) Swapped the HDD for an SSD, game loading times will be much faster
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET much higher quality and wattage PSU that'll happily allow for an upgrade in the future
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 No brainer if you need WiFi
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd stick to W10 for now
NO ANTI-VIRUS SOFTWARE Windows Defender is just fine
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Well worth the few euro's
Price: €1,933.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/BZxuMuUFcY/
