And the budget?This is what I'm going for its mostly used for Gaming / VR - Monitor is Alienware 32 4K QD-OLED Gaming Monitor - AW3225QF
I'm just a little clueless about motherboards?
LIAN LI O11DYNAMIC EVO RGB GAMING CASE
ASUS® ROG STRIX X870-F GAMING WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 32GB) KIT
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
4 x Corsair ICUE LINK RX120 RGB PWM Fan + Controller Kit
ONBOARD 2.5Gbe LAN PORT
Price: £2,266.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/49NQjnWaJA/
Budget £4,500-£5,500And the budget?
Any reason for the RAM?
Unless you're playing games that are heavily modded, in most cases, yes. It's been mentioned on here about Microsoft Flight Simulator needing 64GB RAM but aside from that, 32GB is plenty.Budget £4,500-£5,500
Ram no reason 64 overkill for gaming?
Fair enough cheers. I was just wondering about the motherboard would it be fine for this build I don't really know the differences between them on pcs websiteUnless you're playing games that are heavily modded, in most cases, yes. It's been mentioned on here about Microsoft Flight Simulator needing 64GB RAM but aside from that, 32GB is plenty.
The motherboard is a good option for the level of build, the Strix designs have decent VRM support and good connectivity, they're definitely one of the higher quality boards out there without spending stupid money on things like theFair enough cheers. I was just wondering about the motherboard would it be fine for this build I don't really know the differences between them on pcs website
