What does this mean?
joamea
Log Name: Microsoft-Windows-Diagnostics-Performance/Operational
Source: Microsoft-Windows-Diagnostics-Performance
Date: 19/10/2010 23:37:17
Event ID: 110
Task Category: Boot Performance Monitoring
Level: Critical
Keywords: Event Log
User: LOCAL SERVICE
Computer: WIN-LP0R08P3V62
Description:
Session manager initialization caused a slow down in the startup process:
Total Time : 82648ms
Degradation Time : 72648ms
Incident Time (UTC) : ‎2010‎-‎10‎-‎19T22:32:05.640400000Z
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Diagnostics-Performance" Guid="{CFC18EC0-96B1-4EBA-961B-622CAEE05B0A}" />
<EventID>110</EventID>
<Version>1</Version>
<Level>1</Level>
<Task>4002</Task>
<Opcode>33</Opcode>
<Keywords>0x8000000000010000</Keywords>
<TimeCreated SystemTime="2010-10-19T22:37:17.312800000Z" />
<EventRecordID>10</EventRecordID>
<Correlation ActivityID="{00000100-0000-0000-2C98-4975DD6FCB01}" />
<Execution ProcessID="992" ThreadID="308" />
<Channel>Microsoft-Windows-Diagnostics-Performance/Operational</Channel>
<Computer>WIN-LP0R08P3V62</Computer>
<Security UserID="S-1-5-19" />
</System>
<EventData>
<Data Name="StartTime">2010-10-19T22:32:05.640400000Z</Data>
<Data Name="NameLength">9</Data>
<Data Name="Name">SMSSInit</Data>
<Data Name="TotalTime">82648</Data>
<Data Name="DegradationTime">72648</Data>
</EventData>
</Event>
pengipete
Rising Star
It means nothing in isolation.
Basically, Windows had a slow start-up on your computer six months ago and that is a report of what was happening at the time. Such "problems" are identified all the time - even on the most stable of systems. In most cases, some trivial, one-off event caused a few seconds delay in your normal start-up. Unless you have a problem and a whole load of reports pointing to a single cause, it's of no interest.
The fact that you are looking at event logs suggests that you may be trying to sort out a problem. If so, post back with details and someone should be able to help.
