What do you think about this spec?
Apcar
Hello,
I was just wondering what you guys all thought of the desktop I've just ordered.
NZXT PHANTOM 410 WHITE GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i5-6600K Quad Core (3.50GHz @ upto 4.60GHz)
ASUS® MAXIMUS VIII HERO: RoG, PCI-e 3.0, SATA 3.0, LG1151
16GB KINGSTON HYPER-X FURY DDR4 2133MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 980 Ti - DVI, HDMI, 3 DP
1st Hard Disk
120GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
Corsair H100i GTX Hydro Series High Performance CPU Cooler
WIRELESS 802.11 AC1750 1,300Mbps/5GHz, 450Mbps/2.4GHz PCI-E CARD
DVD Recovery Media
Windows 10 (64-bit) DVD with paper sleeve
Apcar
My budget is £1900 and this build is over that but I had a code that luckily gave me £15 off.
The use of the PC is Gaming. ALOT of gaming.
I bought two monitors with the build which added about £250 extra. Sadly, because this build is quite expensive I couldn't get monitors that bring out the full potential of the desktop. I ordered two ASUS VN248HA 23.8" IPS LED DISPLAY monitors.
EDIT: The build is still in processing so changes can be made.
I would suggest a completely different system that will unfortunately mean cancelling your existing order and re-ordering. The Azure in the review section is £1500 and offers a better system for less (discounted price if no changes are made). That will give you enough money to get a decent 4k monitor.
