What do you guys think of this?
Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
DVI-D & HDMI Monitor Cables
1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£8)
Any advice or comments would be appreciated, thanks!
This spec is ever so slightly over budget, i will probably overclock a little (nothing major), and it is primarily for gaming, but i will also be running programs like Chemdraw and other chemistry related programs.
The reasons i went over budget was because i intend to be using this computer until it is completely obsolete (ie doesnt really work anymore)
The motherboard would allow you to SLI (add another GPU) but the power supply won't (needs to be at least 750w), if you are planning to overclock you can get a pre-overclocked set up that will be covered under warranty at no additional cost just better thermal paste.
ok, can i ask them what Ghz i want them to overclock it too? and i may upgrade to 750W incase i decide to SLI in the future.
However, will it be difficult to find a GTX 670 card to go SLI with?
Edit: i wouldnt go SLI for at least a year or 2
They will OC to a standard clock speed (Stable) , if you click on overclocked systems you will find out the clock speed. A GTX 670 would not be difficult to find, any GTX 670 with the same memory (2gb) would do.
