I've been looking around at the various buying options for the 3080. Unsurprisingly the ROG Strix is often up the top of most lists but it got me wondering when comparing the various models. I'm just doing my homework before I decide on which route to go down, reviews aside I like to try and figure things out with discussion.
ROG Strix OC - ITRO £870 maximum frequency 1935mhz
ROG Strix - ITRO £840 maximum frequency 1740mhz
ASUS TUF OC - ITRO £750 maximum frequency 1815mhz
It was through looking at the above that I wondered why the ROG Strix would be chosen over the OC for the sake of £30. The benefit is pretty obvious with an almost 200mhz OC, which I'm guessing won't be un-noticeable.
The TUF OC seems like decent value with all things considered and would be well worth consideration to save the £120. Manual OC would likely see you closer to the ROG Strix OC figures anyway.
What's your thoughts on it all? Any insights into what you are getting for your money with the high end options?
