What CPU Cooler is in the PCS Vortex ST-S 3070 Prebuild from Curry's?
Hallom8
Edit: After looking at it a bit more carefully, I thought it looked similar to an SE-224-XT ARGB, and a perfect match apart from the ID Cooling logo being replaced with a PCS logo on the heatsink and 120mm fan.
Hi there, I bought a Vortex ST-S a few months ago and I've really enjoyed using it... Apart from the noise. PCS put a Zotac Twin Edge 3070 (the loudest 3070 model), a 175r with two loud corsair fans (which barely cools the system due to awful airflow, to the point where I had to switch the fans out), a CV550 (which barely runs a 3070 setup due to 30 series power spikes but also creates low vibrating noises ocassionally) and a PCS-branded CPU cooler paired with a 10700.
Does anyone know the exact model of CPU cooler PCS put in this build? I know it's likely a modified more common aftermarket CPU cooler because the 175r is branded with an RGB PCS logo instead of a Corsair logo. The CPU Cooler also has a logo on the heatsink. Images and link are attached below.
Thanks for any replies in advance.
...and, unfortunately, most of these 'issues' is why most people on here would never recommend a pre-built from a computer retailer (be it Currys, Dell, HP)...as it's usually not very clear on the exact specs/quality of the components (other than they're usually the cheapest they can find).
Most people would also normally suggest getting feedback on a PCS custom or pre-built before purchasing, as that will stop buyers wasting money on inappropriate (for their use case), inefficient, or non-upgradeable components.
Sorry, can't help with identifying the cooler further than what you've stated...but I wouldn't be surprised if the same cooler (and other PCS-branded components) is sold as a 'white label' component where the buyer gets their own labelling put on.
NoddyPirate
Grand Master
It is listed here as the PCS Frostflow 100 RGB. As you say it appears to be a rebranded ID Cooling SE-224-XT RGB.
