dv8tion242
I get that the one next to the touchpad seems to be the mic, but what are the holes on either side of the web cam? One on the right side seems to have a 'shiny' metallic and deeper bottom whereas the the left side appears to be a bit shallower. Hard to tell though as there is nothing (And I don't go poking in unknown holes).
Tapping slightly all around the case (screen and base) triggers the microphone so it is hard to tell which one is the actual mic.
Is this a secondary mic or just an unused hole in the case? Not that important as such but if they are unused I will fill them up to prevent dust finding its way in.
Otherwise, the laptop has been pretty good since receiving it a few months ago.. Doesn't get as much use as the desktop, but the laptop is quite a bit more pricey to repair. Wish the optical port was a standard TOSLINK but two other machines fill role of HTPC.
