What 4K 27 inch monitor to go for - thoughts?
PC49laptop
To work primarily with NVIDIA® RTX 3070 - 8.0GB. So G Sync or adaptive, 4K good refresh rate. Ideally height adjustable, not too heavy as some can be 9kg plus.
Could be space for 28 inch if perfect spec.
Without knowing what it's for, it's hard to advise?
Also, what's you maximum budget?
PC49laptop
Its for gaming and all round work but are looking to be fairly lightweight as for use in different rooms plugging in high spec laptop. Budget for perfect spec started at £500 but can go higher.
As above, the laptop 3070 is more like the full fat 3060. This would be a 1440p setup.
The proper 3070 is a good entry into 4k but even then you would be looking at 60-120fps depending on the games.
With a £500 budget you're right in the middle of nowhere unfortunately. A good 1440p monitor will be around £300-£500. A good 4k monitor you're looking at £700-£900.
Anywhere in between isn't really worth it as you will be limiting the future usage of the monitor or wasting cash.
