Just changed the SSD in my Cosmos, was really easy, just undo all the screws you can see on the back,remove the M.2 so that you can access the screw underneath it that holds the SSD tray in place, unplug it then remove it from its tray, put the new one in and reassemble.
Oncee fired back up, go to disc management, initialize the disc & create new simple partition, job done in less than half an hour
