Well... Check this spec (Desktop PC)
robmal
I dont know much about computing and I wanted a affordable, powerful all round pc for internet use, gaming, media and school work. Can someone offer some advice??
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
ASUS® P8H67-M LX SI (NEW REV 3.0): M-ATX, USB 2.0, SATA 6.0Gb/s, 2 x PCI
1GB ATI RADEON™ HD5670 - DVI,HDMI,VGA - DX® 11
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
INTEL SOCKET LGA1155/1156 STANDARD CPU COOLER
Price: £564.00 including VAT and delivery.
JonnyPx
Hi, I'm happy to help out. What would be your budget? And would you need a screen,keyboard etc?
JonnyPx
What you have got there is an excellent PC. I would perhaps recommend upgrading the PSU a little bit,especially if you are thinking of upgrading your system in anyway in the future.
robmal
Here is an other idea, with a AMD processor not Intel.
AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3/)
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
STANDARD AMD CPU COOLER
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Quantity 1
JonnyPx
If it is a decent gaming PC, I would recommend sticking to the Intel CPU, it's better for games and most things really. Same with the RAM, 4gb is fine, unless you of course want to spend some extra money lol!
LFFPicard
This should do you well, budget is a bit tight and it all depends on what games you wish to play, but I tried to get you the best Graphics card I could with your budget.
AMD ATHLON II X2 265 (3.30GHz/2MB CACHE/AM3)
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB ATI RADEON™ HD5770 - DVI,HDMI - DX® 11
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
Price: £591.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-top-spec-pc/
JonnyPx
The AMD is still a v. good processor, especially if you are doing rendering and such. The PSU is easy to buy, not so sure about easy to change, but there are plenty of tutorials online. You'd have to check with support if changing part of your system doesn't change your warranty in any way.
robmal
Is Nvidia or ATI better for graphics cards, as i've only ever used a Nvidia, but the reviews say that the ATI 5670 is better than the Nvidia equivalant.
robmal
Also is ATI or Nvidia better for graphics, only ever used Nvidia but the ATI is better in reviews. :L
JonnyPx
Windows 7 home premium is not worth upgrading, it's already very good. And it depends what is the ATI against? The 5670/5770 are good cards.
robmal
1GB NVIDIA GEFORCE GTX 460 - 2 DVI,HDMI,VGA - DX® 11, 3D Vision Ready
Free Item Free Item
FREE Need For Speed™ World Starter Pack with any Nvidia® GTS450 or above!
Quantity 1
£676.00
LFFPicard
The spec I done will still suit you better, I have improved a lot of your components.
Simple as it is ATI is cheaper and therefore more bang for buck, Intel/Nvidia do the grunt work.
With a budget like yours I would stick to a AMD/AtI build as you can get components elsewhere with the saved money.
The processor I chose is a overclock model, but there are very few AMD processors stocked by PCS that are not overclocks. Just because it can be overclocked does not mean you have to.
robmal
I do like you specs but i've never used a AMD or ATI, so Im a bit anxious but I will look into it more. Thanks :)
