Hi every one.
I have a 5 year old Definance III
It has served me pretty well but I currently have a couple of issues.
First CPU heavy applications/games result in eaerything running very hot. I have never repasted and so assume that this will help, or at the very least is my first step. I've ordered some noew paste and will do this this week.
Second, I occassionally (but becoming more common) get a weird pink haze over the screen. It starts from the bottom and is hard to describle but looks like lots of horizontal pink (some green) lines which flicker and move up and down over the lower potion of the screen.
The proportion of the screen affected varies from just a pixel or two at the bottom to 30-45% of the screen.
The normal dsiplay can be made out behind the haze and the computer otherwise continues to work.
I tried to take a screenshot but it doesn't doesn't show up on the screenshot - which makes me think it is probably a hardware issue with the screen?
It is an intermittent proble and shutting down closing the lid before opening and rebooting usually clears it, but not always.
Could it just be a loose connection? If so what sort of connector am i looking for when I open everything up?
Many thanks in advance and sorry that this is a bit of a rambling question...
Ben
Specs:
Defiance Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 6700HQ (2.6GHz, 3.5GHz Turbo)
8GB HyperX IMPACT 2133MHz SODIMM DDR4 (1 x 8GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
512GB INTEL® 600p M.2 NVMe PCIe SSD (up to 1775MB/sR | 560MB/sW)
Defiance Series 4 Cell Lithium Ion Battery (60WH)
Intel 2 Channel High Def. Audio + MIC/Headphone + SoundBlaster X-Fi MB3
GIGABIT LAN + WIRELESS INTEL® AC-8260 M.2 (867Mbps, 802.11AC) + BLUETOOTH li
3 x USB 3.1 Type A, 2 x USB 3.1 Type C AS STANDARD
DEFIANCE SERIES RGB BACKLIT UK KEYBOARD
Windows 10 (64-bit) DVD with paper sleeve
Dead Pixel Guarantee
30 Day Dead Pixel Guarantee Inc. Labour & Carriage Costs
Promotional Item
FREE HOLIDAY SEASON BUNDLE with select GTX 10 Series GPUs!
Ben
Specs:
Promotional Item
