Water / Liquid Cooling in UK, prices?
PlayStationMike
I'm going to order a full water cooling set from Poland for my next desktop, kit includes:
CPU Block - EK Water Blocks EK Supremacy - Plexi Nickel CSQ
GPU Block - EK Water Blocks EK-FC GTX Titan SE / GTX 780 Plexi Nickel
MOSFET Block - EK Water Blocks Mosfet Asus X79 KIT - Plexi Nickel EN
2x140mm Radiator - Black Water Advanced 142
3x120mm Radiator - Black Water Advanced 123 rev. 3.0
Pump - EK Water Blocks EK-DCP 4.0 PWM
Reservoir - EK Water Blocks BAY SPIN Reservoir - Plexi CSQ
Thermometer - Phobya Termometr 2x iG1/4 LCD
Tube/Pipe cutter - Black Water Tube Cutter
Connectors - EK Water Blocks złączka prosta SM10/13 G1/4 Black CSQ
Tubing - Black Water PVC Flexi 10/13 Clear
Coolant - EK Water Blocks EK Ekoolant UV Lime GREEN
I will get fans separately because I'm not sure what I want yet, definitely push-pull config and maybe with Corsair AF/AP series.
I'm from Poland so I feel more 'sure' about quality of the stuff I order cos I know it. But how is it with the prices and quality in UK?
All that above will cost £450 posted and I have chosen all bits on my own.
How much I would have to spend to get a kit like that in UK?
Any particular reason why you want to do it? It will increase the cost significantly and void your warranty on the GTX 780. You could also consider buying a GPU with a pre-installed NZXT Kraken cooler.
PlayStationMike
Reason. I like modding, even modded my car lol. Good looking rig, with water cooling + OC on GPU and CPU, UV LED's and UV Active coolant to improve the looks. I know it will void warranty on CPU because it will be OC and GPU but well that's the only way to do it. Anyone here that build a similar kit but with parts ordered in UK?
Wozza63
Biblical Poster
I nearly did it myself, was nearly half that price I think, was a while ago so I can't remember. Was going to get yellow liquid to match the case etc.
tom_gr7
Life Serving
Yeah I looked at doing it, Was going to cost about £500. If i wasn't so cautious with money i probably would have.
Why the EK stuff? I only heard bad things about EK parts. I can't recall what they were, but it was enough to put me off them.
T
TheGeeza
Was gonna build a loop soon for my system.
I think the price was around £450 for a CPU and GPU loop.
Probably going to put it together in the summer :)
Distinct
Why Push Pull? If you are using SP fans (I recommend you do) there is no need and you will unlikely see gains. Having a high static pressure with one set of fans is good enough. The only thing that would make me go for push pull with static pressure fans would be if you like the looks. I prefer seeing the RAD rather than the fans on the inside of the case so it is not something I would do
