Warbelian
CORSAIR iCUE 4000X RGB Tempered Glass Mid-Tower ATX Case
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
NO RECOVERY MEDIA REQUIRED
After going a bit back and forth the build finally got done and prior to Christmas which was amazing,
Previously the idea was to place the H115i installed on the top, but didn't seem to work out for size due to the RAM,
Also the H115i doesn't seem to be a well fit for the 4000X and 3070TI so had to either swap to the H100 or H150 so went with the H150,
Very snappy as you'd expect, struggles somehow with DOOM Eternal on High Settings, could be CPU, need to benchmark it but currently the 5600X is a place holder.
Will share some Fire Mark results after it finishes installing & all that.
Question, the H150i, has the front fans but somehow I can't seem to change their colour in iCUE, are they controlled stand-alone ?
