Vyper performance
Remmieko
Hello I am thinking about buying the Vyper Laptop with these specs:
Chassis & Display Vyper Series: 15.6" Matte Full HD 45% NTSC LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
Memory (RAM) 16GB Corsair 2400MHz SODIMM DDR4 (1 x 16GB)
Graphics Card NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
1 Hard Disk 1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE
(5,400rpm)
1 M.2 SSD Drive 256GB ADATA SX6000 PCIe M.2 2280 (1000 MB/R, 800 MB/W)
Memory Card Reader Integrated 2 in 1 Memory Card Reader (SD, MMC)
AC Adaptor 1 x 150W AC Adaptor
Battery Vyper Series 46WH Lithium Ion Battery
Power Cable 1 x 1 Metre Cloverleaf European Power Cable
Sound Card 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® AC-9560 M.2 (1.73Gbps, 802.11AC) +BT 5.0
USB Options 1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 4 x USB 2.0 PORT
Now I wonder what you guys think of the performance of this laptop. Do you experience any heating problems and what do you think about the screen? And how does it compare to other top brand (MSI, ASUS, Dell) laptops with the same specs?
And also i saw with other models that it is possible to add a better kind of cooling paste, but that option was not available with this one?
Kind Regards
What will you be using the laptop for? Gaming? Anything else?
There's a review of the Vyper here: https://www.vortez.net/articles_pages/pc_specialist_vyper_15_review,1.html done by tech website Vortez.net
You can check for more benchmarks in games of a laptop GTX 1060 here: https://www.notebookcheck.net/Computer-Games-on-Laptop-Graphics-Cards.13849.0.html
The scores posted by the Vyper in the Vortez review are in line with what you'd expect to see on any other 1060 (unsurprisingly). :)
If you check this forum: https://www.pcspecialist.co.uk/forums/forumdisplay.php?15-Show-off-your-new-PC-Laptop!
you can find a couple of reviews from users too:
https://www.pcspecialist.co.uk/forums/showthread.php?60117-Review-Vyper-Series-15-6-quot
https://www.pcspecialist.co.uk/forums/showthread.php?60185-vyper-laptop-for-music-production
No idea about the paste. I'd suggest asking PCS directly (the forums are mostly for the customer community). If you ask them, do let us know what they say. I was wondering about that yesterday actually.
Remmieko
I got a responce of PCS about the cooling paste:
"You are correct that the cooling options on other laptops do offer additional thermal paste options. We do find however that the thermal operation on both the Vyper and Recoil chassis are well within limitation and guidelines to maintain performance on those high end components.
It does so occur however that the Vyper chassis requires extensive labour for a repaste to be possible. Should you wish to have aftermarket thermal paste be used on this chassis there is paste and labour cost of an additional £20 or 30eu.
I would however put my strong faith in the OEM paste which is used by the chassis manufacturer on this chassis. In our tests is performs very well when compared against our range and even compared against repasted other models with the same spec. The cooling system on this chassis is quite robust. "
