Fans normally relate to temps, so check your temps. When on battery, obviously it's using much less power so makes sense why the fans aren't as active.Hello,
the title basically says it all.
I'm running the laptop in office mode and changing the fan curve doesn't change much.
On battery the laptop is comfortably quiet as it should be.
Is anyone having this issue or know how to fix it.
Cheers
The temps are basically the same then when unplugged with much louder fans. I think the fans relate more to clock speeds then temps on this chassis. Hence them ramping up and down all the time.Fans normally relate to temps, so check your temps. When on battery, obviously it's using much less power so makes sense why the fans aren't as active.
Again like the other post mate my Vyper does not do this.
With mine there is a clear relationship to the fan operation and the temperatures.
I assume you have all the driver installed that PCS supplied?
