Vyper 3 Build
LazBee
Hi Guys, Just ordered then saw the forum, so if there are any issues would be good to know so i can try and amend, or if you just want to say it going to be amazing that will also be great, mainly a work laptop running a variety of engineering software, although not much heavy stuff just more multi tasking, not really looking for gaming but something with the potential to play some if i wanted.
Thank you
Chassis & DisplayVyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
Memory Card ReaderIntegrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor1 x 230W AC Adaptor
BatteryVyper Series 91WH Lithium Ion Battery
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
Keyboard LanguageVYPER 17 SERIES RGB BACKLIT UK KEYBOARD
LazBee
The only thing I’d say, are you sure just 1 500gb drive is going to be enough? Seems very small.
Thank you for your reply, most data is backed up / saved on external hard drives for work use, and dont currently game (although looking to so I can pass time working away) do games use alot of storage space ? The laptop had the option for two drives so is it possible to add a second in at a later date without voiding warranty.
Thank you
Thank you
Games are probably averaging about 50gb per game with latest titles at around 100gb. But even for work stuff, what kind of packages do you work on?
IMHO if you’re resorting to external storage for anything other than backup purposes, the device isn’t up to spec.
