Vortex Series IV 17.3" / Clevo P170SM
Hi there!
I'm going for this setup and I'm wondering if I everything checks out.
As I've never owned an high end device before I hope this one can meet my "expectations".
In what setting configuration would I be able to run games like Battlefield 3/(4), Guild wars 2 and the latest Far Cry with over 70-80 FPS
Also if later I choose to add extra 2x4gb of RAM. Will it be OK, or 2x8 would be better?
Vortex Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4800MQ (2.70GHz) 6MB
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
NVIDIA® GeForce® GTX 780M - 4.0GB DDR5 Video RAM - DirectX® 11
Memory - 2nd Hard Disk
240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd/3rd HDD HARD DRIVE OPTICAL BAY CADDY <----Can they(will they) attach the DVD Drive faceplate bezel onto bay caddy?
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack <----Who is the provider of sound drivers?
GIGABIT LAN & WIRELESS INTEL® ULTIMATE-N 6300 (450Mbps)
Total Order Price £1,636.00
Thanks.
Why 2 SSDs? The GTX 780m should max those games but not 70/80 fps, anything above 30fps is playable.
Windows would go on the first one and the games on the second one, I will add extra HDD for multimedia.
Will the medium settings with AA and other samplings turned off, give me solid frame rate over 70?
I would say anything in the range of 40-60fps is playable, however its not enjoyable.
SlimCini
KC and the Sunshine BANNED
You could get the review Vortex for £200 less than that which is arguably a better build than what you have there...
I'm also pretty sure the Vortex IV can't do anything more than 60fps but I may be wrong.
I'm confused, are you saying that the 780m cant do over 60fps?
what makes the review vortex better, what would you change.
FPS is a personal preference. I've never liked the slowness when the frames go below 60.
SlimCini
The screen won't play anything higher than 60fps. No doubt the 780m may be capable of it, but you'll be maxed at 60fps. Unless you connect it to a higher Hz monitor maybe? But then why get a laptop if you're going to do that...?
The review Vortex is just cheaper because of the discount it has, that's the main improvement. Very similar otherwise.
