Vortex laptop from 2012
Hi
I am looking for some advice, I need to replace a failing WIFI card in the laptop and thought it would be a good idea to upgrade to AC as I am buying a new router due to a Fibre installation.
Currently I have "WIRELESS INTEL® N-2230", does anyone know if any of the AC specification cards will work?
Hi
the killer ac1535 is a good one, personally I'd always opt for killer over intel because of better driver support as well as better hardware.
SlimCini
KC and the Sunshine BANNED
You can buy the killer 1535 from pcs as an individual component given you have a laptop from them. Ring up and ask.
Thanks for the advice gents, from speaking with PCS it would appear that no AC card is compatible with my laptop. Looks like a USB dongle then.
