I have my spec for the Vortex - Which includes:
Primary use will be gaming although will replace my desktop (3.2Ghz Black, GTX 285)
I have a couple of questions on the setup;
1.) 16Gb RAM - will I really see the difference between using 8Gb and 16Gb RAM - if not should I go for better 8Gb RAM (1600) rather than lower 16Gb RAM? The same 16Gb RAM is close to £75 between 1333Mhz and 1600Mhz - is that worth the upgrade?
2.) 180Gb - This will be my primary drive and all games, etc will be stored on the secondary internal drive - whats the startup time on these drives and is it worth upgrading to the 180Gb SSD 520 ?
3.) Is there any noticable difference between the 2Gb GTX 675M and 4Gb 680M? I have come to realise that just because the number and RAM is higher doesn';t necessary mean its a better card! I assume both will play modern games as well as my desktop.
4.) Arctic Compound - Is this a necessity for a laptop upgrade rather than using the standard thermal paste?
5.) Matte vs Glossy - I know Glossy is suppose to be better for gaming on laptops but is it really noticeably if I get Matte or Matte AUO?
6.) Whats the difference between the normal wireless card and the Wireless Gaming 1102 Card? They both appear to be 'N'
TO ADD:
7.) Can you turn off Touchpad Mouse? (HP have this facility) Just wondered
Thanks,
Neil
- i7 3720QM (2.6Ghz)
- 16Gb RAM (1333Mhz)
- 180Gb SSD (330) Hard Drive with 750Gb SATAII
- 4Gb nVidia GTX 608M
- Arctic MX4 Compound
- Wireless Gaming 1102 Card
TO ADD:
Thanks,
Neil
