Vortex II Missing Half The Spec?
PlasticTastic
Hi, this is my first post here. My friend bought a laptop from here and recommended it a few weeks back so I checked out and found the custom laptop I'd really like. Yesterday I went on it again to show my friend, and the main reasons I wanted the laptop were missing.
(Vortex II 15.6)
Samsung 16GB 1600Mhz RAM
nVidia GTX 580m
Where did they go? Have they stopped selling those parts or just temporarily out of stock? And is there a GTX 6XXm range coming out, cause I read somewhere they won't be for a while?
Rapcar
The GTX 580m is being rebadged as the 680m. believe it will be available this month. E-mail PCS to check.
PlasticTastic
I do apologise, I only just noticed the thread about the Vortex III all the way down. Thanks though.
If a mod sees this, you can remove the thread (and possibly sticky the V-III one to avoid someone else doing the same! ;) )
Finn
According to another post the 16gig of 1600mhz memory option was an error as it only supported a maximum of 8 gig @ 1600mhz.
