Hi gents,
Just bought a 15.6 Vortex 4 with a Haswell and 780m. Apart from having to wait a month for it, all is (after I figured out how to get the 780m running as default via the NVidia PhysX) well - it's an elegant, fabulous machine, for something so small the power under the hood is simply amazing - well done PCS.
However.
I bought a new 2013 model 60' LG 3D TV to compliment it, with the aim of playing 3D Blu-ray and games. Windows 8 says "stereoscopic 3D enabled" however no games/3D blu rays worked. (Yes I'd downloaded NVidias 3D play software)
Sooo after spending an age bouncing mails back n forth with NVidia customer services, who were surprisingly swift/helpful (in stark contrast to PCS, see below), they advised me that the issue lies with PhysX ports - there is no port for the 780 - see attached screenshot. They said that this is not configurable via their software and only the laptop manufacturer can change/set these ports.
Sooo after a couple (like 2) emails (which PCS took an age to respond to) explaining the problem to PCS....wait for it....they asked me a couple of very basic/silly questions and then literally stopped responding!!! I've bought 4 PCs from PCS and to be honest expected more.
I bought this lappy with 3D gaming/movies very much on the agenda, but it seems all this new tech is now an utter waste, at least as far as 3D is concerned. If these ports are not configurable and 3D isn't possible on the V4s (other than the dedicated 3D model) then PCS really should make this abundantly clear.
Penny for your thoughts?
Kind regards
Anton.
However.
Kind regards
Anton.
