Frank100
Rising Star
Hi all,
I wanted to canvass for opinions on the wi-fi capabilities of different routers provided by the main broadband providers after experiencing several months of hopelessly inadequate wi-fi service from my Virgin Media Super Hub 2.0.
I've been with VM for about 8 years and been very happy with the service for most of that time. When VM decided to start making their own routers rather than buying them in, I think the problem started. The Internet is awash with people unhappy with the performance of their VM routers but a recent Which? report suggested they performed well. I'm now on my third Super Hub and if I weren't so busy and they weren't so hard to get through to, I would be reporting this all the time.
Presently I am getting about 0.3Mbps download speed via wi-fi on the 2.4Ghz channel. Some of my devices support both and when connected to the 5GHz channel perform well enough. It is the 2.4GHz channel that is hopeless. Obviously I have tried all the things you can try. Different channels, although the router supports auto switching. I've tried different physical locations for the router and I've tried manually assigning IP addresses to key devices and using DHCP for everything. In short every conceivable setting has been tried.
As a number of my devices only support the 2.4GHz channel I'm at the stage of considering going to another provider. The speed and reliability of wi-fi is paramount for my needs. I was wondering what experiences people had had with Sky, BT and so forth.
I'm also considering buying a wi-fi router of my own and using the VM one in router mode only. This means spending money that I don't think I should have to spend, but changing provider is a hassle and I don't know I'm going to get a better service anyway. Everything else about VM I am happy with. When I do get through to the VM call centre they very excitedly tell me that "all my problems will be resolved now and to have an outstanding day" or they just send me another router. It doesn't fix it and I'm still not having an outstanding day yet.
When I use my mobile phone as a hotspot in the same room as the VM router my laptop jumps onto it and gets vastly superior speeds than the VM router provides. I have unlimited download and 100Mbps wired connection but the irony is, if I want to download a large file on a mobile device, I can only do it with my 4G contract.
Any thoughts and opinions would be gratefully received.
Frank100
Frank100
