VBIOS edition?
Hi, I purchased an Octane 1080GPX several years back from PCS, and recently the 1080 burned itself out. Finding a *nearly* identical model for sale, I jumped in hoping it would work. Unfortunately, although physically identical, it was the model 'b', where the laptop had come with the model 'c'. Scrambled screen.
So I tried replacing the VBIOS with a copy from the 'c' 1080GPX. Scrambled screen.
Having tried most of the VBIOS listed for the 1080GTX MXM on Techpowerup, and all result in scrambled screens, am I missing something important?
Should I be aiming for a copy of the 'b' version or 'c' version VBIOS? Will either of them work, considering neither of them worked so far.
Is it something in the BIOS itself that needs changing?
Posting here instead of DMs as perhaps any help may help someone else in a similar situation.
Can you post your full specs from the order page on your PCS account?
Octane Series: 17.3" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
64GB HyperX IMPACT 2133MHz SODIMM DDR4 (4 x 16GB)
NVIDIA® GeForce® GTX 1080 - 8.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
1TB SAMSUNG PM961 M.2, PCIe NVMe (up to 3000MB/R, 1700MB/W)
1TB SEAGATE HYBRID 2.5" SSHD Drive, SATA 6 Gb/s, 64MB CACHE (5400 rpm)
2nd Storage Drive
2TB SERIAL ATA II 2.5" HARD DRIVE WITH 32MB CACHE (5,400rpm)
Order Reference: 1141470​
2nd Storage Drive
You would need the specific GPU for that chassis as different GPUs versions require different power levels which may not align with the power delivery on that chassis.
I personally wouldn’t be spending any money on trying to resurrect such an old system anyway, even if you were to get it working again, it’s not going to even be able to run most modern games due to significantly low VRAM
