usb 3.0?
Bsrz
Rising Star
HI guys so obviously usb 3.0 is the future and on the case im buying with my pc it has 2 usb 3.0 ports on the front of it.
the HAF-X case
quick question when im on the config my pc, what will I need to select on the usb section to take advantage of these? or will they be connected and used even if I select the (6 usb 2.0 ports min 2 front ports) as standerd??
thanks!
vanthus
Member Resting in Peace
I think it depends if the motherboard has the necessary USB 3.0 ports to connect the front USB 3.0 case ports.
Most modern motherboards should have this option.
Bsrz
Rising Star
ah the motherboard Im thinking of using is the asus sabertooth x79 socket 2011 ROG
vanthus
You should be fine then,that motherboard has 2 USB 3.0 ports at mid-board.
Specifications.
6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (6 at back panel, black, 8 at mid-board)
niklad
I have the same motherboard in my PC, and they do connect the front USB3 to your board (if your case uses the mid board headers they use that, if the case uses the back usb port as a hub they'll connect that.)
