Upgrading PC RAM
dr_wanqenstein
Hi all -
I got my brand new PC Specialist desktop 2 years ago this very month during what was the great GPU shortage of the pandemic! Happy to report no issues, however, I'm thinking it might be time to upgrade my RAM from 16gb to 32gb.
Specs below if needed:
CaseCORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Change to: LIAN LI LANCOOL II GAMING CASE
Processor (CPU)AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
Change to: 8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
1st M.2 SSD Drive512GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingSTANDARD AMD CPU COOLER
Change to: CoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler
l guess what I'm asking here is for advice on what to upgrade to? I have very little knowledge of PC building and relied heavily on this forum to get the above build in the first place!
Should I just order another two 8gb sticks of the same RAM as above? Are they easy to fit myself? I'm sure if I opened the case up I'd be able to find the RAM and where it's located.
Thanks,
What's making you think you need to up the RAM? What are the uses? 16GB is still perfect just now. If you were buying a new system then 32GB would be recommended to keep it fresh for a few years but there are very few needs for more :)
Steveyg
More RAM doesn't increase performance. RAM is one of those things that's it's either used or it isn't and no in between so you only add more RAM if your current RAM is being maxed out
I'd echo @TonyCarter and say a dedicated M.2 SSD for your games would be a much more worthwhile upgrade. You see a much bigger difference gaming from an SSD than from a HDD
