My current system purchased around 7 months ago on the next-day pre-built section of PCS:
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK)
Promotional Item
Get a discount code for 20% off peripherals at Corsair.com
Promotional Code ZZ-PCS-B73C-49BX
Terms & Conditions
Promotional Item
Get Avatar: Frontiers of Pandora™ with select AMD products. (G)
Promotional Code FYWUWBS5GEFTJHVTLFPU
Intel® Core™ i9 24-Core Processor i9-14900KF (Up to 6.0GHz) 36MB Cache
ASUS® PRIME Z790-P (LGA1700, DDR5, PCIe 5.0)
32GB Corsair VENGEANCE DDR5 5600MHz (2 x 16GB)
24GB AMD RADEON™ RX 7900 XTX - HDMI, DP - DX® 12
Partial changes were made on amendment [2966397] to: 24GB GIGABYTE RADEON™ RX 7900 XTX GAMING OC - 2 x HDMI, 2 x DP
NONE
NOT REQUIRED
PCS FrostFlow 240 Series ARGB High Performance Liquid Cooler
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Microsoft® Edge
Welcome Book
PCSpecialist Welcome Book
As it has been pointed out to me, my current system is not really fit for purpose and components needs upgrading. I'm currently looking at upgrading the PSU and cooling system and I will approach the case in the new year. Below are the components I'm looking at to try and improve this system's performance. Any advice would be appreciated.
In regards to the cooling system, I don't really know which to choose.
I have had 2 RMAs so far. One for the CPU and the other for the GPU. Something will fail again if I don't sort this out.
Promotional Item
Terms & Conditions
Promotional Item
NONE
NOT REQUIRED
Microsoft® Edge
Welcome Book
